HD130 Series Connections Log Out | Topics | Search
Music Man Amps Discussion Forum » Speaker Impedance, Wiring & Switch Settings » HD130 Series Connections « Previous Next »
Larry Marseglia (lrmars)
Username: lrmars
Posted on Friday, September 15, 2006 - 12:14 pm:
My HD130 Reverb head does NOT say the speaker outputs on the back of the amp are wired in series. There is apparantly a way, with a continuity tester, to verify this. If the jacks are in fact NOT wired in series, is this something a tech can modify? I have 2 four ohm cabinets I would occasionally like to run with this amp.
LRMars
Posted on Saturday, September 16, 2006 - 03:08 pm:
You can have it wired that way pretty easy. Just requires a shorting jack and the time. Any QUALIFIED tech can do it.
