Jonathan Moore (jondanger)
Username: jondanger
| Posted on Tuesday, October 05, 2010 - 06:28 am: | |
If the speaker outputs in my 210 Sixty-Five don't specify that they are wired in series or parallel, should I assume that they are series? The impedance switch has an 8 ohm and a 4 ohm setting. The two 8 ohm speakers are connected in parallel, making a 4 ohm load without an extension cab. I built a cab to sit under the combo, and it sounds right with the switch set to 8. Just looking for confirmation. This is the model with the phase inverter. Thanks! |
