Music Man Amplifier Dating? Log Out | Topics | Search
Music Man Amps Discussion Forum » Identifying Models, Dates & Chassis Numbers » Music Man Amplifier Dating? « Previous Next »
Todd Rohrer (roxide)
Username: roxide
Posted on Sunday, January 26, 2014 - 02:20 pm:
Hello I have a White Tolex'd Music Man RD100 The chasis number is 2100-RD-CAL and the Serial Number is DP10294. Thanks again.
Posted on Sunday, January 26, 2014 - 02:41 pm:
Hi Todd,
one obvious thing to look at is a date stamp. If you remove the upper back cover, quite often there is a date stamp on a sticker on the right hand side of the amp chassis (seen from the back). To narrow down the vintage you can answer these questions:
1. Does the amp have 6L6 or EL34/6CA7 output tubes?
2. Does the EV speaker have a date code on it perhaps?
3. I've never seen silver badges on a white (pinwale) MM, but they may exist out there. Does yours have black or silver badges?
Sincerely,
Lars Verholt
http://captain-foldback.com
http://housebrandmusic.com
Posted on Sunday, January 26, 2014 - 02:43 pm:
Oops - sorry, misread your post. Your amp is the RD-100 head, not the 112 combo so forget the second question in the last post.
Sincerely,
Lars Verholt
Username: roxide
Posted on Thursday, January 30, 2014 - 02:34 pm:
1. 6L6's for the output tubes.
3. If by silver badges you mean the place where the identification numbers are embossed then silver. If not then what do you mean badges?
Posted on Thursday, January 30, 2014 - 03:39 pm:
THe front badges will either be black on silver backing or silver on black backing'
Here's the two side by side'
Username: roxide
Posted on Thursday, January 30, 2014 - 03:53 pm:
Black Badge.
Username: roxide
Posted on Monday, February 03, 2014 - 02:23 pm:
Any idea on a date? I have been researching and it looks like it is between '80 and '84 maybe?
Rob Flindall (flinly)
Username: flinly
Posted on Monday, February 03, 2014 - 07:56 pm:
Have you removed the chassis from the cabinet? Good chance there is a date written on the inside with a sharpie marker. The transformers are also stamped with a serial number that identifies the year the tranny was built.
