Ohmage for 115rh cab? Log Out | Topics | Search
Music Man Amps Discussion Forum » Speaker Impedance, Wiring & Switch Settings » Ohmage for 115rh cab? « Previous Next »
arby
Posted on Monday, January 05, 2004 - 11:05 pm:
i have a M.M. 65, and a 115rh cab and i dont know what to set the switch to. 4 or 8? i checked the speaker with a multi meter but im still not shure. help?
Terry
Posted on Tuesday, January 06, 2004 - 09:10 am:
You did not say what the OHM meter is telling you!!
arby
Posted on Tuesday, January 06, 2004 - 10:26 pm:
It says about 3, but the meter jumped aound so much I could not say for shure. are there manuals for finding the ohmage of these amps out there?
Terry
Posted on Tuesday, January 06, 2004 - 10:48 pm:
You should have a 8 OHM speaker. If someone put 4 OHM speaker in it, it would read about 3 OHM. It should not be jumping around!! Are you checking at the speaker or the wire that plugs in the chassis ?
alot of wires are bad from age or the speaker may not be good. Check right on the speaker then check the wire by itself for the jumping.
arby
Posted on Wednesday, January 07, 2004 - 09:25 pm:
I checked it out with a new meter and every thing is cool. it is an 8 ohm speaker. It was my multimeter that was faulty. (boy..i feel stupid)Thanks for the help.
arby
Posted on Thursday, January 08, 2004 - 10:39 am:
One more thing, why does the speaker cab have a face plate that says "75"? I looked at the model chart that says it is 65 watts. Whats up?
By the way, I live in Ontario and i have been looking for years (to no avail) for information about these amps. Thanks for the help and info.
