Selander
| Posted on Thursday, January 12, 2006 - 03:33 am: | |
I'm a Swedish guitarist and a big fan of MM-amps. I own 2 of them at the moment. I've heard somewhere that the Hi/Lo function is bypassed on amps exported to Europe. I can't say I notice any difference when switching it. Does anybody know if this is true? |
| Posted on Sunday, January 22, 2006 - 05:16 pm: | |
Can't really say-I've never seen a schem from an export. I would find it hard to believe that they would defeat that function but if you have one of the SS driver versions, there is almost no change from one to the other. Is that the model that you have? |
anon
| Posted on Wednesday, January 25, 2006 - 04:47 am: | |
i have an EX model (hd 130 12ax7) and i can say that the low power switch works. it may not seem quieter but you will pickup headroom in hi mode. |
Bob Moore
| Posted on Monday, April 10, 2006 - 08:20 am: | |
I have owned a RP 100 head for 20 + years and can't tell any difference in HI/LO. The switch was broken and had to be replaced when it arrived at the dealer and I always wondered if the wrong switch was installed. I watched the repairman fix it and he double checked to make sure it was right when we couldn't tell any difference. |
| Posted on Tuesday, April 11, 2006 - 07:10 pm: | |
When switching between High and Low power settings, there will NOT be an increase or reduction in volume... this is not changing the gain of the circuit it is simply increasing or decreasing the plate voltage on the output tubes. This will effect the apparent headroom. If you are pushing an amp into output tube overdrive in low power then switch to high power, it will clean up and you will have to push it harder & louder to get back to the same level of overdrive. Steve |
