arby
| Posted on Monday, January 05, 2004 - 11:05 pm: | |
i have a M.M. 65, and a 115rh cab and i dont know what to set the switch to. 4 or 8? i checked the speaker with a multi meter but im still not shure. help? |
| Posted on Tuesday, January 06, 2004 - 09:10 am: | |
You did not say what the OHM meter is telling you!!
arby
| Posted on Tuesday, January 06, 2004 - 10:26 pm: | |
It says about 3, but the meter jumped aound so much I could not say for shure. are there manuals for finding the ohmage of these amps out there? |
| Posted on Tuesday, January 06, 2004 - 10:48 pm: | |
You should have a 8 OHM speaker. If someone put 4 OHM speaker in it, it would read about 3 OHM. It should not be jumping around!! Are you checking at the speaker or the wire that plugs in the chassis ? alot of wires are bad from age or the speaker may not be good. Check right on the speaker then check the wire by itself for the jumping. |
arby
| Posted on Wednesday, January 07, 2004 - 09:25 pm: | |
I checked it out with a new meter and every thing is cool. it is an 8 ohm speaker. It was my multimeter that was faulty. (boy..i feel stupid)Thanks for the help. |
arby
| Posted on Thursday, January 08, 2004 - 10:39 am: | |
One more thing, why does the speaker cab have a face plate that says "75"? I looked at the model chart that says it is 65 watts. Whats up? By the way, I live in Ontario and i have been looking for years (to no avail) for information about these amps. Thanks for the help and info. |
