Kenneth
| Posted on Tuesday, November 30, 2004 - 08:12 am: | |
Hi I´ve read a lot of the posts regarding correct impedance, but i´m still a little confused regarding the right setting for my amp. I have a music man 212 65 combo and have just replaced the speakers with 2 8 ohms eminence. i only use the internal speakers, there is no extra cabinets attached. is it correct that my speakers are wired in parallel and therefore i should use the 4 ohm setting? Kind regards Kenneth
| Posted on Tuesday, November 30, 2004 - 02:32 pm: | |
The original 8-ohm speakers from the factory were wired in parallel and the amp was set for 4-ohms when using only the internal speakers. If you didn't change the speaker wiring when you replaced the speakers, this should still be the case. Steve
Kenneth
| Posted on Tuesday, November 30, 2004 - 03:00 pm: | |
Thanks Steve for the fast respond.. I´ve connected them the same way as they were before . and it was the original speakers I replaced and I suppose they haven´t been rewired. I´ll go with the 4 ohm setting then. Thanks again Kenneth |
