uposb4
| Posted on Tuesday, June 15, 2004 - 05:04 pm: | |
Were tilt back legs an option for MM 212-HD 130 amps? i would like to put some on mine if anyone knows where i can get a set. seems like i saw a MM with them but couldnt tell if they were original or from another company. |
Langley
| Posted on Wednesday, June 16, 2004 - 08:56 am: | |
Fender's tilt-back legs are patented, so chances are good that those on a MMan are user add-on's. They come in 14" 16" 19" lengths, #30 - $40. Do a Google on "Fender tilt-back" and you'll find the links.
| Posted on Saturday, June 26, 2004 - 03:25 pm: | |
I have never seen "factory" tilt-back legs for Music Man amps, only the Fenders. I have added Fender tilt-back legs to several amps in the past. As Langley stated, they can be ordered in different sizes from a Fender parts dealer for about $40. The 19" would be used with a 410-sized combo, the 16" with a 212 and the 14" with a 210. The fender kits contain all the required hardware. Steve
Stephan J.
| Posted on Monday, March 20, 2006 - 06:24 am: | |
Hi, do the tilt back legs also work with an amp that has wheels attached? Should I maybe use longer ones, i.e. a set of 19'' for a HD-212 130 on wheels? Cheers, Stephan |
| Posted on Wednesday, March 22, 2006 - 07:50 pm: | |
Depends on two things: the desired angle that the amp must sit at when tilted back and how high up you must mount the legs so they do not extend past the cabinet when in the stowed position. Steve |
