Bob
| Posted on Wednesday, July 13, 2005 - 02:48 pm: | |
Will this work to get a lower volume or a bad idea? |
| Posted on Saturday, July 23, 2005 - 08:13 pm: | |
Not a good idea! This tube is usually used in an amplifier with no more than about 450 Vdc on the plates. You plug these into a Music Man with more than 700Vdc plate voltage and you will arc-over, blow tubes, pop a fuse and perhaps put your amp in jeopardy! You need to use the original 6L6 tubes to have any chance of tube survival in your Music Man amp. Steve
Mike H
| Posted on Saturday, October 22, 2005 - 08:33 pm: | |
I also have an RD50. These amps are different than the other MM amps. They do not have 700 volts on the plates; however, they do have about 450-500 volts, as I recall, which is atill a lot for 6V6 tubes. Also, since these amps have fixed bias, this would further complicate the issue of swapping tubes. So, I agree, stay with the 6L6. Just my $.02. |
| Posted on Friday, December 30, 2005 - 08:23 pm: | |
Yes, the RD50 amps "only" have a 585Vdc plate voltage! This is still way too high for safely using a 6V6! Steve |
