Aaron
| Posted on Thursday, January 19, 2006 - 11:46 pm: | |
I purchased a MM 115 sixty-five recently, and since I have no idea just how old those tubes in it really are, I would like to re-tube it. I am new to owning tube amps, and the only thing I am slightly confused about is that little shielded 12ax7 tube. Can I go ahead and just get another 12ax7 tube installed? If so, any recommendations? Or should I do something different all together? Any and all advice and ideas would be greatly appreciated. Thanks in advance! |
| Posted on Friday, January 20, 2006 - 06:49 am: | |
The 12ax7 is used as a Phase Inverter. Any GOOD 12x will do. I do like JJ's simply because they seem to last and sound good. There is no biasing or adjusting required. Mike/ |
Aaron
| Posted on Friday, January 27, 2006 - 04:18 pm: | |
Thank you very much. Therefore, the new tube does not need to be shielded when I replace it, correct? |
John Drexler
| Posted on Friday, January 27, 2006 - 05:38 pm: | |
If you mean the little metal sheath that goes over it, no...that is just to help protect it. |
