Dirk Wacker (doc_holiday)
Username: doc_holiday
| Posted on Sunday, August 12, 2007 - 04:55 am: | |
With the 6l6GC-STR from TAD I found a very good sounding power-tube and I really like the sound they make. But with the Ruby Tubes 12AX7-C in the overdrive channel Iīm not so satisfied. The gain is very weak and the tone is very brittle, something you donīt really need in a MM amp. Any suggestions for a tube with a good and smooth overdrive tone with some gain and low noise ? |
Mike (mike_h)
Username: mike_h
| Posted on Wednesday, August 29, 2007 - 10:30 am: | |
I've found that on a stock RD 50, I like to reduce the gain to get the sound I like. I really like a 5751 (gain 70) in place of a 12AX7 (gain 100). I've also tried the following: 12AT7 (gain 60)- Not bad, but not quite enough gain. 12AU7 (gain 20)- Great sound, not enough gain 12DW7 (gain 20/100)- I like this a lot, 2nd to a 5751. I've never used TAD tubes, but I have found few Chinese tubes that I like. I've used Ruby tubes, and I've never cared for them. I prefer Sylvania, phillips, RCA, GE, and JJ (depending on the tube type) for the preamp tube. I use Winged SED 6L6 for the power tubes. |
