Marc
| Posted on Thursday, May 29, 2003 - 10:13 pm: | |
I've got a MM HD210 One*Fifty I'll never part with. I don't give a fat baby's dick for those with the attention span of a chicken among ye who piss themselves whenever forward-thinking mods of any kind are put forth. In fact, for you toads, I purposely 2X coated the tolex exterior with the same brown-tint shellac I did my Bassman 5F6A with, and gold hand-painted the faceplates. So here's my question; I've always hated that budget-rent-a-car, cheese ass power-on light MM slapped on these fantastic amps. I'd like to slap an interchangable color crystal on my MM. Have any of you done this? What's specifically involved in doing so, to make it fit right and look as wonderful as this born-to-rock-the-blues gig animal plays? Thanks, Marc mmulay@cox.net |
Marc
| Posted on Friday, June 06, 2003 - 02:46 am: | |
My God, this site either isn't book marked or you guys are phenomenally devoid of spunk and humor. I'd hate to think that the MusicMan has fallen into the hands of an entire generation of passive-aggressive life support systems for a dry clit! C'mon fellas-- TELL me that cat fart power ON switch does any justice to our beloved BEAST? It's like a Morris Minor horn on a Lamborghini. I'd like to slap a cool purple Mesa-looking ___tagonal light on mine. No tech's have a positive input on this? Yours truly, Herr Doktor Robo-Negro von Meat Fart  |
aussie carl
| Posted on Saturday, June 07, 2003 - 09:56 am: | |
i agree dude, i sused it out its a wierd lamp that is not screwed in with a nut, its sorta held in place by a plasticy thing, i would love to change it too |
| Posted on Saturday, June 07, 2003 - 04:59 pm: | |
Some of us over-work for a living, so we only get to sample your prose once every few weeks! I have often thought about replacing the neon pilot assembly found in MM amps with a standard jewel-lense holder for a #47 pilot lamp (as found in the Fender amps of the glorious past). It would make the MM amps look less like a Mr. Coffee in a dark room. I personally haven't done this, but it WOULD require modification of the chassis as well as the front panel. This would entail not only complete disassembly of the front panel (and removal)and machining of the new mounting hole (chassis and matching hole in the front panel) but also a change in wiring. The original neon lamp assembly has its own dropping resistor built-in and wires directly to 120VAC when On. The #47 pilot lamp used with the jewel-lense pilot light assemblies is typically run through a dropping resistor from a heater supply voltage (unregulated). |
Marc
| Posted on Friday, June 20, 2003 - 06:45 pm: | |
Steve-- Thank you. re; "...It would make the MM amps look less like a Mr. Coffee in a dark room..." GOOD one. That's enough info. for me bring to my local tech. I'm gonna do it when I replace the speakers next year as a gift to myself (pls. see the research I did elsewhere on the site). Much appreciated and glad Aussie Carl is among those who also "saw the light" as something halfway between an alarm clock in need of slamming one on the wife's vibrator kicked to life under the bed by the cat. Here's to reasonable Mods! Marc |
Pict
| Posted on Tuesday, September 28, 2004 - 09:10 pm: | |
There's always gaffa tape. |
Spino
| Posted on Monday, January 10, 2005 - 10:28 am: | |
Hey Guys! So has anyone sussed this out yet cuz mine don't shine anymore and I'm lookin' to insert a Blue Fender type jewel in it and that's about all the moddin' I'll be doin'.Has anyone changed the speaker in their RD100 for somethin' else and what's the diff soundwise and is it worth it?
John Drexler
| Posted on Monday, January 10, 2005 - 09:12 pm: | |
After reading Marc's posts I'm enthralled and astounded! Not because of the light thing...who gives a crap about a light if you've got a life? But I didn't know that Frank Zappa had given lessons! |
Clayton Choate
| Posted on Tuesday, January 11, 2005 - 12:25 pm: | |
SHH! John. You might wake him up! |
HAHA
| Posted on Tuesday, January 11, 2005 - 03:12 pm: | |
Mine started shinning green for no reason?...hehe |
John Drexler
| Posted on Thursday, January 13, 2005 - 05:04 pm: | |
I had that happen once. Then I looked at what I was smoking and... |
Spino
| Posted on Saturday, January 15, 2005 - 02:14 pm: | |
Hey! John D You got any Class at all ??? Remember "Each to his own"!!! |
William Michel (bill)
Username: bill
| Posted on Saturday, January 06, 2007 - 01:50 am: | |
I just found 4 Fender type jeweled lights. I am satisfied to leave them sitting on a shelf nearby the Mister Coffee machines. Sure, I dream about the best way to poke a hole in the chassis and plate in one, assembled swoop...but no, Leo must have made them that way for a reason. {A small punch could be ground with a centering tip to fit exactly the existing hole, and attached to a small die in a screw driven fashion....} I won't do it but it's nice to have the lenses and holders around... |
| Posted on Thursday, May 08, 2008 - 03:05 am: | |
ok guys i know this is a old post but i do beleave that there are people wanting to get rid of mr coffee for a jewell lens of thier favorite color as i did on my 100rd.here goes :first i unsoldered the connections to the light,next i took the lamp assembly and carefully pulled off the lens with needle nosed pliers.i then roughed the metal ring that held the old lens,super glued that to the plastic tube that holds the bulb and put some solder on the metal sleave.i then had to tap the hole in the chasis with a 9/16 tap.screwed in the jewel lens,and put a bit of solder on end of the jewell lens,i then CAREFULLY soldered the tube to the lens .after it cooled i the put a little super glue on the assembly for good measure,resoldered the wires back on and waaa lahhh it worked,note:do at your own risk.you can see this in my post:my 100 rd in the brag about your amp section of this fine site |
