Tom Siegel (2tone10)
Username: 2tone10
| Posted on Friday, January 23, 2009 - 06:10 pm: | |
Help - It made smoke this time!!! The reverb was a bit scetchy on the old 112 RD 50, it would sound really lush then dry up. If I tipped the amp forward or back the reverb would start working again. Long story short after poking at the tank a bit I got the reverb back but noticed that the amp was breaking up (no headroom) at lower volumes. I swapped out the tubes and fired her back up. I got a loud hum then smoke.I have it appart and found some fried resistors but for the life of me I can't find them on the schematic. I have pictures that I can email, maybe somone can help me track these resistors down? Also there is a green wire hanging loose by the input jack, I am assuming that it goes along with the orange one on the tip but would like confirmation if possible. Thanks, Tom |
Username: 2tone10
| Posted on Saturday, January 24, 2009 - 08:05 am: | |
Here is a picture of the damaged area Any help would be greatly appreciated |
Username: 2tone10
| Posted on Saturday, January 24, 2009 - 10:23 am: | |
So the two brown resistors appear to be 2w 27 ohm. From close examination of a previous picture of my board and the resistors, the small one on the left appears to be 680 ohms and the one on the right 39k. I have been over the schematic and can't find any 2w 27 ohm resistors..... |
Username: 2tone10
| Posted on Saturday, January 24, 2009 - 10:29 am: | |
Oh - I am also assuming the green wire should be connected back where the orange one is, on the tip of the input jack...  |
Username: 2tone10
| Posted on Tuesday, February 24, 2009 - 01:58 pm: | |
Got it figured out with the help of my friendly amp tech who has a scope. The resistors, 1 transistor and an op-amp were taken out by a bad tube. I also had a headroom problem. This one is embarrassing. I had replaced the grid resistors at one point. They are 470 ohm, the supplier didn't have them, and I was in a hurry so I grabbed 47k. If you ever want to cut the power of your RD 50 down to 15 watts - this mod's for you.... |
| Posted on Wednesday, February 25, 2009 - 05:56 am: | |
That board looks pretty crisp. I think I'd probably fix the board traces with some tag wire before I went too much further. THose traces are awful thin. |
Username: 2tone10
| Posted on Friday, February 27, 2009 - 07:30 am: | |
Thanks Mike - I actually got the amp up and sounding awesome. The board looks fine from the backside and I always test the traces with my meter after I replace a component, I hope it holds together. Thanks for all of you input on this and other topics. You guys are great |
