carl, australia
| Posted on Wednesday, October 08, 2003 - 09:40 am: | |
VALVE RATTLE hey i know it happens but whats the go - is it bad - do all valve types do this? how can WE get around it, it doesnt happen in any other valve amps. cheers all |
Lengley
| Posted on Thursday, October 09, 2003 - 11:01 am: | |
If that the rattle you describe originates from within the valves (lite tap on them -while cold), then your valves ought to be replaced with a matched set and biased. Try playing with a bit less bass. (BTW, slight rattle can be normal.) If the rattle originates elsewhere, try doing some 'general tightening' - cabinet screws, speaker's, chasis retainers, etc.. If it's from a speaker, you may need to replace. If it's coming from within the chassis, bring the amp to a tech, to avoid getting fried - or worse. |
aussie
| Posted on Saturday, October 11, 2003 - 04:10 am: | |
thanks so much lengley i had done these checks and found out it is definately the valves as they do this cold and i do say they have got progressively worse the thing is the amp ounds great so i dont know you know? thanks for your thoughts i guess ill start saving for a set, cheers. anyone else think rattlley valves need to be replced????????????????????????????????? ???????? lets start a discussion forum??????? |
stig of australia
| Posted on Tuesday, April 06, 2004 - 03:28 am: | |
my hd130 tubes also rattle. which is fine when playing loud and can't hear it, but a pain in hte arse when playing quietly. can it be stopped completely? |
langley
| Posted on Wednesday, April 07, 2004 - 12:00 pm: | |
The insides of a tube are delicate, Rock-n-Roll never forgets. Some anti-rattle ideas that I've tried... Sturdier tubes; $$$ Rubber 1/64" isolation strips between the chassis top and the cabinet's mount points (helped a bit, improved chassis ventilation unexpectedly); Cheap. For a non-combo, buy some nice new mushy rubber feet for the head, or just isolate the head from the cab by putting the head on a non-vibrating surface. Cheap.
