Terry Loose (terry)
Username: terry
| Posted on Saturday, July 29, 2006 - 01:54 pm: | |
I bought a cabinet off of E-bay that was a combo. Someone sawed the cabinet down to make a head and did a very poor job. It was too small to put back together. It did have a good top and bottom, so I've been trying to get the sides out of the finger joints at the top that were glued together at the factory. I soaked it in water...all that did was tighten it up like a barrel in water. I then used some solvent that was supposed to loosen the glue, but the joints are so tight, the solvent couldn't get in. Then I was boiling some sweet corn on my grill and thought.....why not put the corners in the boiling water after the corn was done. It worked!!! After about 10 minutes, I could tap the side panel away from the top plate. Then you could wipe the old glue off the cabinet and it was like having a new top. Now I can make two new side panels and make this a little RD-50 combo again. Thought I would share my experience/thoughts with you. |
