Greg Williams (gwmn)
Username: gwmn
| Posted on Saturday, August 03, 2013 - 10:08 pm: | |
I'm having a real hard time sourcing new electro' caps for my amp. 150uf/50v. I can find lead free ones, maybe those would be fine. Also would the easy to find Sprague's work, as far as physical size goes, for the 100uf/450v's? Were they all silver from the factory? I have some blue Mallory's in there. Got this amp from a rummage sale for $25.00. Original speakers and tubes. What a great amp. Haven't had one since the 70's and I think it was a 410-65. Any help would be greatly appreciated - thanks |
Username: gwmn
| Posted on Saturday, August 03, 2013 - 10:56 pm: | |
I'm sorry if if looks like I'm bragging about the price I got this for, but you must understand that I can't even win a turkey!}} |
| Posted on Sunday, August 04, 2013 - 07:04 am: | |
Well, the 150 at 50's are getting harder. https://taweber.powweb.com/store/capord. htm Weber is slow to pack and ship though. The Spragues should fit fine. Tride has the 100@450's but for the 150 @ 50 you might have to gang two together in parallel.Remember that you can go up in voltage rating without any problem. Why the hell can't I get stuff like that for $25.00 (jealous!). Mike. By the way, you CAN use the radials in the 150 @ 50 slot. Ugly but they work. THEY are cheaper at mouser that way. Nichicon is good stuff. |
| Posted on Sunday, August 04, 2013 - 07:45 am: | |
By the way, AES has 100's and 50's that you can gang together. Mike. |
| Posted on Sunday, August 04, 2013 - 07:55 am: | |
OK-did some more snooping. Seems like here-has the best asst. Some are radials but thay have axials too. http://www.newark.com/jsp/search/browse. jsp?N=422+217007+810045290+810053110+810 029780+810029779+810029773+810049424&No= 0&getResults=true&appliedparametrics=tru e&locale=en_US&divisionLocale=en_US&cata logId=&skipManufacturer=false&skipParame tricAttributeId=&prevNValues=422+217007& mm=1000002||,1000360||,&filtersHidden=false&applie dHidden=false&autoApply=false&originalQu eryURL=%2Fjsp%2Fsearch%2Fbrowse.jsp%3FN% 3D422%2B217007%26No%3D0%26getResults%3Dt rue%26appliedparametrics%3Dtrue%26locale %3Den_US%26divisionLocale%3Den_US%26cata logId%3D%26skipManufacturer%3Dfalse%26sk ipParametricAttributeId%3D%26prevNValues %3D422%2B217007 |
| Posted on Sunday, August 04, 2013 - 11:35 am: | |
Mouser has them. Part # 75-TVA1311-E3 www.mouser.com The 100uF/450V part # is 75-TVA1718-E3 . These will fit in MM amps too. Good score! Well worth bragging about. Cheers, Lars Verholt |
Username: gwmn
| Posted on Monday, August 05, 2013 - 11:55 am: | |
Okay, I found the two 100/450's and the five 150/50's. I should replace the two 20/450's I'm guessing also, right? Any others I should be concerned about? The amp is pretty quiet. By the way, mine is the 12AX7 driver model (2275-65 chassis?) It looks like some have been replaced already if they were all silver from the factory. Three of the 150/50's are blue Mallory's and the two 20/450's are also blue Mallory's. But maybe I should just do all of them and start fresh. I love the sound of this amp. Warm, very warm with the original "fat boys". Tried some early 2000's winged C's but didn't care for them, even after a few bias adjustments. I really am impressed with this forum. You have done a great job and I really appreciate the help - thank you. gwmn |
| Posted on Monday, August 05, 2013 - 01:16 pm: | |
Unless you can find a date on the chassis saying "changed on such and such a date", I would just change them all. ESPECIALLY the ones, in your case, on the driver board and bias supply board. VERY IMPORTANT. Blue Mallory's could still be 20 years old. |
Username: gwmn
| Posted on Wednesday, August 07, 2013 - 11:11 pm: | |
Hello again. I'm finally getting time to order caps. Will the mouser P/N 647-TVX2W220MCD work fine for the 20uf's under the hood? I do have some brand new sprague 20/450's in another amp I could pull. Thanks again |
Username: gwmn
| Posted on Wednesday, August 07, 2013 - 11:23 pm: | |
Hello again, Just wondering if the mouser p;n 647-TVX2W220MCD will work fine for the 20uf's under the hood. I do have some new sprague atom 20uf/450's in another amp I could pull if it's critical to stay at 20 here on these amps. Thanks again |
Username: gwmn
| Posted on Wednesday, August 07, 2013 - 11:29 pm: | |
Didn't mean to post the same question twice. Didn't see the first one, so I thought I messed it up. Thanks |
| Posted on Thursday, August 08, 2013 - 06:21 am: | |
That will be fine. That's pleny close unless they are drastically out of spec, which I doubt. |
