Larry Natalini
| Posted on Tuesday, July 02, 2002 - 01:45 am: | |
I can't find a reverb tank on the post that's a short tank for my 112RD-50. Does anyone have any info? |
| Posted on Tuesday, July 02, 2002 - 02:11 pm: | |
The schematic (1650RD.pdf file in the schematic area of this web site) shows an Accutronics 8BB2A1B reverb spring assembly. The Accutronics Reverb model info page is at: Accutronix Reverb Tank Specs You should be able to order this from an Accutronics dealer. Steve
Larry Natalini
| Posted on Wednesday, July 10, 2002 - 05:40 pm: | |
Thank you, Steve. L.N. |
| Posted on Tuesday, January 16, 2007 - 10:43 pm: | |
This site explains the number/letter configuration to match up your reverb unit. http://www.accutronicsreverb.com/prodspe c.htm This is the unit for the RD-50 (8BB2A1B) REVERB TANK, MED DELAY, SHORT TANK, SLM, MM RD-50 AMPS P-R8BB2A1B CE distributors has these as well. 190 ohm input, 2,575 ohm output, medium delay, grounded input, grounded output connectors, horizontal, open side down mounting. Used in SLM and MM RD-50 amps |
