louloomis
| Posted on Monday, October 06, 2003 - 08:31 pm: | |
hi. the reverb on my 112 RD-100 sounds really bad. it sounds faint and not very ballsy. even turned up to 10 it is wimpy and has little decay or depth. do i need to replace the tank or is there something up with the cicuitry of the amp itself? the reverb is supposed to sound good i take it. are there any diagnostic things i can do myself? repair guys around here won't touch anything for under 150 bucks. when i use the insert jacks and an external reverb all is well...but i'm sure the insert jacks don't share the same part of the circuit as the send/return to the reverb... any ideas would be great. thanks, LL |
langley
| Posted on Tuesday, October 07, 2003 - 10:27 am: | |
Some simple tests to help you diagnose... Does symptom occur with/without the footswitch plugggd in? Do you get any 'snap crackle pop' if you move the reverb send/receive wires around? If you 'hit' the reverb unit when it's on do you get the characteristic 'Boing' of the springs? Are all the reverb's/chassis RCA jacks CLEAN and fit TIGHT? connected correctly? (see schematic if needed) |
