david manzullo
| Posted on Wednesday, March 23, 2005 - 10:14 pm: | |
I have two MM amps,..the 212 sixty five is the first issue...My amperex EL34 tubes just went microphonic on me. I have a pair of 6CA7EH tubes, do I need to bias the tubes before I can use the amp again?   |
| Posted on Thursday, March 24, 2005 - 06:33 am: | |
If you have a 12ax7 Phase inverter tube in your amp, yes you need to rebias. If no tube, they are pretty much plug and play ALTHOUGH I WOULD STILL CHECK THEM. If you have 12ax7 PI tube, bias tubes to approx 21-23ma idle current PERE tube and you will be fine. Mike. |
david manzullo
| Posted on Thursday, March 24, 2005 - 12:18 pm: | |
Yes...I have the 12ax7 PI tube, so can I bias the new tubes myself, never done it before. Is it diffucult..? what do I need? |
| Posted on Friday, March 25, 2005 - 06:45 am: | |
Well, if you are a gambling man, you can bias that amp with just a digital multimeter. You would just have to adjust to get .5 volts as measured at pin 8 on the octal tube socket(power tube). I say gambling man because I don't like biasing by taking the total bias current of a pair of tubes. I prefer to check bias current PER TUBE so that I know the tubes are equal. If you are sure they are balanced(and yet, how would you know?), you can do it this way. I would prefer that you use a bias adapter and check out the current per tube. This way you can see if you have one hot tube or not. Mike. |
Jay Hammond (jead)
Username: jead
| Posted on Tuesday, January 11, 2011 - 09:52 pm: | |
I'm new to the board and loving the info you people are kind enough to share. I just got a 212-65 and plan to swap out the groove tube El34's with JJ EL34L's. I have the 12ax7 version (Phase Inverter?). Just to confirm, If I've been reading correctly, the Bias trim is the blue pot nearest the power tranny (towards the outside of the board) and I should be aiming for 21 to 23ma per tube with octal probe sockets, Have I got that right?? I'm wondering about the other trim pot. Is that for trem? Is there any point in tweaking that? Thanks in advance. |
