Andrew Wilson (awilson40)
Username: awilson40
| Posted on Wednesday, June 21, 2006 - 08:39 pm: | |
If I have my 210HD130 (new tubes, original caps) set on 3-4 or above on the volume and the master at 7 or so I start getting some OD type distortion when the guitar (carvin with passive humbucker) is around 80% maxed. If I switch to high power then its clean at the same settings. I keep the volume at about 2 on the preamp when on low power to keep it clean at max guitar volume. Is this normal or signs a cap job is needed?? Thanks |
Username: awilson40
| Posted on Friday, June 23, 2006 - 06:09 am: | |
I ordered the required caps, BTW Newark had all of them in stock. Question....Old caps have the Pos end marked Correct ?? while new will have the neg end marked ?? |
| Posted on Saturday, June 24, 2006 - 09:29 am: | |
Actually, they aren't "marked" but it's easy to tell one end from another. THe ground end lead goes directly into the metal can and the "positive" end has a rubber or plastic insulator. Your caps are probably due and it's cheap insurance. |
Username: awilson40
| Posted on Saturday, June 24, 2006 - 03:29 pm: | |
That makes sense, Thanks Mike |
Username: awilson40
| Posted on Sunday, November 12, 2006 - 01:23 pm: | |
Well. new caps didnt help this, Per my other post asking for help |
