Matthew Lehr (mattl)
Username: mattl
| Posted on Thursday, May 01, 2008 - 04:59 am: | |
What can I do ti filter out the radio stations my HD 130 tunes in? Makes recording with this amp difficult. |
Peter Maziar (mosfet)
Username: mosfet
| Posted on Thursday, May 01, 2008 - 03:48 pm: | |
Install a line filter? shield the wiring at the first stage (and anywhere else they are microphonic to the touch)? Make sure the grid resistors on the tube sockets are in tolerance? Just a few suggestions, without actually seeing the amp... Please be careful to discharge the main filter caps properly before you do anything...  |
Walter Jowers (sonofswamp)
Username: sonofswamp
| Posted on Thursday, May 01, 2008 - 11:13 pm: | |
Somewhere online -- and I can't remember where -- there are documents that show a fix for the RF problem with MM amps. I think it was on the Ernie Ball website, but I can't find it there now. Maybe one of the regulars can direct you to the info. WJ |
| Posted on Friday, May 02, 2008 - 12:52 am: | |
you can find it right here on this site !http://pacair.com/mmamps/Documents/MM%20 Service%20Bulletins%20All.pdf hope that helps |
| Posted on Friday, May 02, 2008 - 01:01 am: | |
or... http://www.pacair.com/discus/messages/72 9/730.html?1095273722 if you want to download just one of the bulletins |
Username: mattl
| Posted on Saturday, May 03, 2008 - 07:51 am: | |
Thanks Folks I think the bulletin will fix the RF problems. Ill let you know. |
