Cliff Goodwin (bigbluz)
Username: bigbluz
| Posted on Tuesday, December 15, 2009 - 11:32 am: | |
Got my first MM, an 112 RP65. Sounds good, but the Phasor is not working. I didn't get a footswitch with it, and I'm not sure if a footswitch has to be plugged in in order for the Phasor to work. There are two RCA inputs right next to the reverb tank inputs, I'm assuming for the Reverb/Phasor on/off. If a switch is needed, will any standard two button Fender footswitch work, or do I need something different? The MM manual shows the Reverb / Phasor footswitch, it looks like a standard Fender footswitch. If the Phasor should be working without the footswitch, where's the best place to start troubleshooting? It doesn't work at all right now. Side note; this came with an EV Force 12 speaker in it, which I'm assuming is not stock? Thanks! |
