Todd Rohrer (roxide)
Username: roxide
| Posted on Sunday, January 26, 2014 - 02:20 pm: | |
Hello I have a White Tolex'd Music Man RD100 The chasis number is 2100-RD-CAL and the Serial Number is DP10294. Thanks again. |
| Posted on Sunday, January 26, 2014 - 02:41 pm: | |
Hi Todd, one obvious thing to look at is a date stamp. If you remove the upper back cover, quite often there is a date stamp on a sticker on the right hand side of the amp chassis (seen from the back). To narrow down the vintage you can answer these questions: 1. Does the amp have 6L6 or EL34/6CA7 output tubes? 2. Does the EV speaker have a date code on it perhaps? 3. I've never seen silver badges on a white (pinwale) MM, but they may exist out there. Does yours have black or silver badges? Sincerely, Lars Verholt http://captain-foldback.com http://housebrandmusic.com |
| Posted on Sunday, January 26, 2014 - 02:43 pm: | |
Oops - sorry, misread your post. Your amp is the RD-100 head, not the 112 combo so forget the second question in the last post. Sincerely, Lars Verholt |
Username: roxide
| Posted on Thursday, January 30, 2014 - 02:34 pm: | |
1. 6L6's for the output tubes. 3. If by silver badges you mean the place where the identification numbers are embossed then silver. If not then what do you mean badges? |
| Posted on Thursday, January 30, 2014 - 03:39 pm: | |
THe front badges will either be black on silver backing or silver on black backing' Here's the two side by side'
Username: roxide
| Posted on Thursday, January 30, 2014 - 03:53 pm: | |
Black Badge. |
Username: roxide
| Posted on Monday, February 03, 2014 - 02:23 pm: | |
Any idea on a date? I have been researching and it looks like it is between '80 and '84 maybe? |
Rob Flindall (flinly)
Username: flinly
| Posted on Monday, February 03, 2014 - 07:56 pm: | |
Have you removed the chassis from the cabinet? Good chance there is a date written on the inside with a sharpie marker. The transformers are also stamped with a serial number that identifies the year the tranny was built. |
