Spino
| Posted on Monday, February 14, 2005 - 11:56 am: | |
Hi to the Archivists I got me a RD112 100w with the following info Chassis No 2100RD Id 2100 Serial no 08949DP Weight 27k Logo Black background White Sticker on back at right says 83-1 Trans (Left) 200-130 250 EIA606-103 " (Right) 4-130 EIA 606-121 I'd appreciate it if someone could tell me when this was built and if the speaker would be a EV model cuz it does'nt have a sticker of any sort .The magnet on the speaker is round and has a hole in the center with a wire mesh .Thanks |
Spino
| Posted on Monday, February 14, 2005 - 12:00 pm: | |
.......Forgot the tubes 2x6l6's |
T. ROGERS
| Posted on Monday, February 14, 2005 - 05:32 pm: | |
I also own a MM RD112 100....I PURCHASED MINE NEW IN 1980 AND I BELIEVE THIS IS THE FRIST YEAR THEY WERE OFFERED.. YOUR SPEAKER IS A EVL12 ..MINE HAS THE SAME..MM DID NOT PUT A LABLE ON THE EV SPEAKER ON THIS MODEL...THE SPEAKER MAGNET IN THIS AMP IS VERY HEAVY AND THE FRAME IS A ALUMIUM CAST.. I HAVE PLAYED MINE ALMOST EVERY WEEKEND SINCE I OWN IT AND HAS NEVER FAILED ME.. HOPES THIS HELPS TERRY |
Spino
| Posted on Tuesday, February 15, 2005 - 09:29 am: | |
Hi Terry ....Yeah I got this badass about a month ago and can't wait to gig it.Seeing as you've had yours so long maybe you can give me a few pointers as to replacement tubes,that is, if yours runs on 6L6's.Thanks Man! |
T. ROGERS
| Posted on Tuesday, February 15, 2005 - 06:29 pm: | |
Hey Spino... I use Groove 6L6's and have had since i replaced the orginals....these babies work great for my kind of playing,which is rock, blues, and country. These tubes will lasted about 2 years and were biased before i played thur them..the tube were also a matched pair... I will say the orginal GE slyvania tubes were great and lasted a long time before i replaced them.. There are sereval differant brands on the market these days, but the groove tube seems to do the trick for me..... I hope i helped you a little.... TERRY
