| Posted on Monday, August 26, 2013 - 08:58 pm: | |
Thanks to Michael Kaus, a factory component layout diagram has surfaced for the RD50 series! This is the first component layout I have ever seen for ANY Music Man amp. It certainly appears to be a scan from a factory drawing. It is labelled as being for an "RD50a" unit, which is probably the model with the "Mid Shift" control. The drawing only shows component locations on the board and does not indicate connections to off-board components. When I get the time I will add this for download but until then, here is the link to the file: Music Man RD50 Component Layout Diagram Please note that is only shows locations Reference Designators so you will need the schematic to convert the designators into part values. Steve |
